GPSMAP H1 series first impressions and bugs
Just received my GPSMAP H1 series device and have been playing around with it for a bit. Software version is 3.04.
The UI has improved over the 66 and 67 series in my opinion, it is much more intuitive. Touch screen works well (not tested in rain yet), and the device is quite responsive.
I did already notice some issues though:
  • When you have the dashboard enabled on the Map app, and you move the cursor on the map, the dashboard disappears (which is fine). However if you press Quit to exit cursor mode, the dashboard doesn't reappear. You have to move to a different app or the home screen and return to the Map app to get the dashboard to appear again, or pan the map and press the re-center icon.
  • When previewing a course on the map with the map full screen, it is not possible to zoom in or out by a pinching gesture on the touch screen but only via the + or - buttons or via the zoom controls on screen. The pinching gesture does work on the Map app.
  • When you load a course with course points and go to the map app, the course points are shown as expected. If you now stop navigation and return to the home screen with the Map glance on it, the map glance will still show the course points but not the course line. The course points are cleared when you go the map app again and return to the home screen.
  • In dark mode the Outdoor Maps+ buildings layer in combination with the TopoActive map is not visible in urban areas. The two colours are too much alike.
  • When you move through the item types in the Saved app (ie between all, courses, waypoints, activities), often the Waypoints list is not loaded when switching to the Waypoints tab.
I'll report these to support, but hopefully others can confirm these issues as well.
And for feature requests, it would be nice to be able to sort in the Saved app, like you can in the Explore app.
