Garmin 67i with CityNavigator Maps for Driving
I was looking for information on this forum for how to set up the Garmin 67i with CityNavigator maps for navigation while driving. I couldn't find the information in one place on the forum but after pulling the information I needed from several places I was able to set it up. I thought I'd share the steps here in case they might be useful to anyone else. This worked for me.
After installing a CityNavigator map.
ENABLE THE CITY NAVIGATOR LAYER, DISABLE THE TOPOACTIVE MAP LAYER
Press MENU
Select Map
Press MENU. A list of selections will appear.
Select Map Layers
You will see the selections: Shaded Relief, TopActive, CityNavigator
Turn OFF the TopoActive layer
Turn ON the CityNavigator layer
CONFIGURE THE DEVICE FOR DRIVING:
Select Setup
Select Routing
On the Routing menu select
  • Direct Routing - No
  • Activity – Automobile Driving
  • Lock on Road - Yes
  • Course Navigation – Prompted
  • Course Alerts – On
SETUP DISPLAY TO SHOW CURRENT DIRECTION:
Press MENU
Select Map Setup
Select Orientation
Select Automotive mode (displays a perspective with your current direction at the top)
