Looking for guidance/instructions to transfer way points from GPSMAP67i to GPSMAP86sci.
You could either connect the devices to a computer and copy the GPX files containing the waypoints in the Garmin\GPX folder to the other device.
Or you could pair both devices with the Explore app and use collections to move waypoints from one device to the other. Be sure to check https://support.garmin.com/en-US/?faq=8bca2cTmnj4yHfHvUl4Pt8 for more info on this.
You can also use Garmin BaseCamp to receive the data from the GPSMAP 67i and then to send the data to the GPSMAP 86sci. Instructions are here: Backing up, Viewing, and Transferring Data Using BaseCamp
