I have a new unit that has been updated. When I plug the unit into the phone the 67i has a dialog that it generated a GPX file. Then the screen shows a USB symbol yet it will not connect to Garmin Explore on the phone. If I unplug the phone it eventually goes off and I can repower with the on/off switch
When I have advanced recording to generate FIT and GPS and hook it to the phone the screen shows the dialog for generating GPS and then locks up. No button will cause an action. The on/off switch does nothing. Screen is on and eventually goes to the USB icon. After several minutes the device reboots. Then it is a brick with a black screen and the LED next to the power button is blinking green for several minutes.
Then I get a beep and can power on the device.
The unit will connect and synch wirelessly to Explorer.
When I connect the unit to the computer and Explorer I get a dialog that says the 67i is not compatible with Explorer then it sets up a download for GarminUpdater. That won't work either.
Something has a glitch.
