Garmin GPSMAP 67i Officially No Longer Supporting Garmin GB Discoverer 50K SD Cards and Maps
I have just purchased a Garmin GPSMAP 67i and the device no longer supports older Garmin SD Cards and Maps.
For instance, when installing a Garmin GB Discoverer 50K SD Card, you get a “map not supported error”.
Garmin’s Customer Service (if you can call it that) have confirmed that the Garmin GB Discoverer 50K SD Card and Topo map is not supported by their new GPS devices, and consumers need to spend another £150 buying a new SD Card / Map.
Garmin Customer Service “The map is not compatible due to its age, it only supports the newer mapping, this is a limitation of owning older mapping im afraid, you would need to purchase the new maps.
When asking if it’d be possible to get an update for the map, Garmin respond “Mapping purchased comes as they are and cannot be updated I'm afraid, this is by design, The map you have is not eligible for any updates”.
I haven’t yet checked whether my TOPO France, Switzerland, US, Spain, Iceland maps work, but don’t be fooled into thinking you can use your old maps in Garmin’s latest devices - you can’t.
Options are 1). Don’t buy and upgrade to a new device, 2). Spend hundreds of pounds more buying new maps.
Once again, it’s Garmin demonstrating that their customers rank very low in the order of priorities and the company will use every opportunity to make more money from us.
  • I don’t have Garmin sd card maps but I do have older late 90s and early 2000  Garmin dvd maps and free maps from gps file depot, and they all work fine when loaded from Basecamp onto an sd card. Plus I do have some older sd card maps from an independent map company and they all still work. Must just be some Garmin only maps. Free lifetime map upgrades on my 6” Garmin vehicle gps. I think others will be able to let you know a little more about Garmin sd card maps, and which ones won’t work any longer.
  • Sorry to hear about situation. There's a respectable number of free compatible map options, I have installed them and they work quite well. I hope this helps.
  • It appears that other Garmin maps are compatible either, such as the Garmin Topo Spain v5. Be warned that your old SD cards won't work.
