How to uninstall maps on gpsmap 64s
I know this forum is for the 66i, but i figure the steps are the same.  I recently installed a map of sweden, went there and visited, and now need to remove the map.  Note that map was downloaded from garminworldmaps.com.  I performed a factory reset, but that doesn't seem to remove maps.  I did go in manually and deleted the file i believe to have been the sweden map on the device, while it was connected to my laptop, and opening folders via file explorer.  I can't get basecamp to remove any maps.
Next i installed the Garmin Huntview Plus Wisconsin map.  My device is extremely slow, and i'd like to remove this map as well.  I believe that because i purchased it from garmin.com, that i will be able to redownload it later, if i want to use it.
Is there a way to remove all the maps on the device?
I'm going on a trip, where i'd like to load a smaller amount of info, to make it operate quicker.
Also, i should mention that i have a 32GB sd card loaded in the unit.
