What is the difference between "Route Planner" and "Course Planner" applets?
What is the difference between "Route Planner" and "Course Planner" applets?  And what does that mean in practical use?  And if the differences don't matter, why are there two applets?
Short Answer:
The question above led to a long thread after I posted it in 2022.  Since then, forum managers started pointing other threads here when they ask the same question.  In summary, Garmin uses the vocabulary "route," "track," "course" and "activity" to describe what are all generally the same thing.  Namely, each is an ordered set of 3D points (lat, lon. elev.) that defines a path relative to the Earth's surface.  So the simplest way to understand them is to consider how they vary from one another.
Routes and tracks verses courses and activities
The difference between routes and tracks on the one hand and courses and activities on the other is the data format in which the points are stored.  Tracks and routes are stored in a .gpx format, which is an easily transported universal standard.  You can open a .gpx file in text software like Word or Notepad, and the data sort of makes sense.  Courses and activities are stored in .fit format, which a Garmin proprietary format that is highly compressed (needs less storage space and makes no sense if you open the file in a word processor) and can store additional information like heart rate generated by Garmin devices that's not part of the universal .gpx standard.  I'm nto sure, but I believe the compression is accomplished without loss of resolution.
Tracks and activities verses routes and courses
The difference between tracks and activities on the one hand and routes and courses on the other has to do with how they are created.  If you define the ordered set of points explicitly, say when you're planning a hike, Garmin calls that a route or a course.  If a Garmin device creates the set of points based on its location, then Garmin calls that a track or an activity. An obvious consequence is that points in routes and courses don't have timestamps, whereas Garmin devices timestamp the points the devices record.
The differences matter because (and only because) they affect how you manage your navigation data.  In a perfect world, there would be only one word for all four concepts, and users would be asked to distinguish what they want when they export or import navigation data.  But like most high-tech things, these terms developed over time.  So possibly for backward compatibility, Garmin continues to use all four words to keep things simple for long-time users, even though that makes things painfully complicated for new users.  In an attempt to minimize the pain, Garmin hides some of the distinctions, but that means users can be surprised and upset when what they've created is not what they meant to create.  It also means that users can have a hard time finding their navigation data in a Garmin device if they don't understand how and why Garmin uses so many terms for what are all basically the same thing.
Caveat
I'm not an expert.  So there are probably mistakes in the above.  I hope they are minor and don't defeat the purpose of sorting out the main confusion.
  • can navigate with a course
    exactly what I've said.
    Courses are not dependable of maps, but can use them.
    Routes are totally dependable of a map.
  • Thanks for explaining. However, as an average user, once I have created the Route from a Track (which is easy), I also have the option to create a Course from the Route... So the question is, riding often OffRoad, what is the best for guiding me? The Course or the Route? And which one gives me faster info? (I have bought all the necessary Maps from Garmin and I use a Montana 700)
  • I don't think you'll find a discernible difference between the two, in terms of speed or navigation quality.
  • It's not a matter of speed.
    It all depends on the application of the route or the course/track.
    You need to see the whole picture.
    - If you are creating your "adventure" using the device itself with Garmin's maps you can use ROUTES (no need to any conversation) but you might be at the risk of missing a feature or a path. As it happens with all maps providers Garmin not always has the most complete map. None has...
    - Let's say you drawn your "adventure" on a desktop app or get one from a friend. NEVER use a ROUTE unless you have absolute certainty that your device has THE SAME MAP (and version) that the route was created. USE a course or a track once they are not map dependable.
     And if you want an assurance that you are going to pass 100% over the course/track you have load keep "RECALCULATING" always set to off.
    I only use "route" when for some reason I need to create a "adventure" on my device on the fly but for that it would be better to use Google maps/Waze, etc...
  • Why do think a route is somehow dependent on a specific map when you USE it? Once you draw the route, it’s just a sequence of points. No reference to the map at all AFAIK.
    Edited to add: if you choose a routing technique such as road routing, you may be directed differently depending on the map in use. Any map which is capable of the chosen routing technique should get you to the same place. But intermediate details may differ.
    because it is...
    Should I Use a Route or a Track?
    • Routes are best suited for reaching a specific destination, or set of destinations, when the path being taken is not important. When navigating a route, directions will be provided either as a straight line to the destination(s) or, when using a routable mapping product, as an automatically calculated path using available roads and/or trails. If you go off course on a route, the path will recalculate based on your current location.
    • Tracks are best suited when it's necessary to travel on a very specific path to reach the desired destination. When navigating a track it's possible to recreate an exact hike or ride that you or someone else has completed previously. If you go off course on a track, the GPS unit will redirect you back to the original path rather than recalculating a new one.
    Differences Between Routes and Tracks | Garmin Customer Support
    Additional comments to try explain:
    A ROUTE can "result" on several paths depending on several factors such as: the device you are using, the map within the device, and other.
    A track will always result in the same path. No matter what device or map you using. You can even follow a TRACK with no map installed in the device.
  • A route is calculated by the GPS software. If there are several options to reach a destination, the GPS will choose one of those options (ie, the path being taken is not important).
    A track is not calculated by GPS software, it is recorded. When it's important to take a very specific path, the track represents that specific path.
    None of this has anything to do with the map.
  • None of this has anything to do with the map.
    No map no route... and the map has to be routable because there are some that aren't.
  • True, no map, no route. True the map has to be routable.
    That has nothing to do with the question. The question is, given the person has a Montana 700 and maps, is he better off using courses, tracks or routes?
    The answer is not map dependent.
