I con not find out what is the setting inreach remote on the 66i
I can not find any explanation to it in the manual
What is it used for?
The inReach remote feature provides the ability for another device to exercise limited control over the 66i. Typically, the other device is a wearable such as a fenix watch. The connection between the 66i and the other device is via ANT+, which is why the settings are buried under Sensors on the 66i.
There is some ANT+ pairing dance that is required to set this up. My 66i is already paired - and I can't find an option (other than Restore Defaults, which seems like a big hammer) to un-pair so I can repeat the process. I believe that the 66i can only be paired with one device at a time. The fenix watches (at least) can be paired with multiple devices at the same time (although I think only one can be active at a given time).
The 66i manual information on pairing ANT+ devices is outdated and useless. I did find this article which appears to indicate that pairing is controlled entirely from the "other" device.
I did go far enough to verify that a watch with no enabled iR devices DOES search as if it want to pair. Since my watch is paired with every iR device I own, I can't test the actual pairing process.
The remote control function allows you limited control over the device - start/stop tracking, see received messages, etc. This article has a more complete description of the features.
thanks, I have no such ANT+ devices, so it is not for me. I was just curious what this setting is for.
