The specs for the 66i state a track logs point limit of 20,000 (https://buy.garmin.com/en-GB/GB/p/623975#specs).. is this truly the case, specifically for *recording* of tracks by the unit itself?
That would suggest using 1-second recording you can only record a track for a maximum of just over 5.5 hours - that doesn't sound right for a device with 16Gb internal storage (even if the majority of that might be taken up by maps etc.)?
(I'd expect there to potentially be a hard limit on the number of track/route points on an imported track/route attempting to be routed.. but for the creation of a track file surely that's just appending another point to a file / series of files until storage space is full up, no?)
As comparison, I've just had a look a long ride (450km) I did last year recorded with an Edge 1030, again using 1-second recording: moving time of 17hrs10min51secs = calculator suggest this should be 61,851 track points = looking at the resulting GPX file there are 61,777 track points (I'll let it off for missing a small number over that time/distance!).
Does anyone have experience of recording for say 6hrs+ (using 1-second recording) on the 66 series?
TIA
