Find Menu "Use Map" no longer shows after menu item reordering
I have reordered the Find menu to reflect what I use most from the Find menu. Some items only display (Waypoints for example) if they have content. However, "Use Map" used to appear, if I edit the order of Find menu items "Use Map" still appears, but if I press the Find button, "Use Map" is no longer there in the Find menu icon view. I have restored defaults and "Use Map" still does not appear.
Some explanation of this behaviour or how to solve the "Use Maps" item being missing would be greatly appreciated.
Sort order or Find menu items
First item in the Find menu item order is "Use Map".
Use Map not displayed in the Find menu
"Use Map" is not there!
NOTE: Neither is Waypoints - but as stated above, I have no Waypoints at present and I have verified if I create waypoints then "Waypoints" appears in the Find menu icon view.
