I am in need of some, but do not have a GPSMAP 66i to get them myself.
If anyone with a GPSMAP 66i is willing to capture some specific screen images for me, please respond.
I will send detailed request privately.
Thank You!
Thank You!
I can grab screen captures for you.
Please send email to my user name at google mail!
Thank You!
Which screen captures do you want?
Messaging? Map?
Weather? Something else?
GPSMAP 66i Screen Captures!
The following may look like a lot of work, but in reality it will only
take a few minutes time. I have tried to provide as much detail as
possible to make the process easy to follow.
Remember, the Main Menu for the GPSMAP 66i can be opened at any time,
from any page, by pressing (Menu) > (Menu).
A. Preparation:
1. Press (Menu) > (Menu) (Returns you to Main Menu)
2. Open Setup > Profiles > +Create New Profile (we will make a specific
profile just for GPSrChive testing so as not to interfere with any of
your existing profiles)
3. You can leave the Profile with the given name (something like
"Profile 7" or similar), or rename it, at your discretion. Works just
fine either way.
4. Choose: Setup > Display > Appearance > Mode = Day
5. Choose: Setup > Display > Appearance > Day Color = Classic Blue
6. Choose: Setup > Display > Appearance > Screen Capture = On
7. Choose: Setup > Display > Backlight Timeout = Stays On
8. Press (Menu) > (Menu) (Returns you to Main Menu)
B. Add all Applications to Main Menu:
1. Open Setup > Menus > Main Menu
2. D-PAD (Up)
3. Select Add Page > Applications (if Applications is not available, Go
to Step 7)
4. Select first available application in list and press (Enter) -
application will be added to Main Menu
5. D-PAD Down
6. Return to step 3 until 'Applications' is no longer available
7. Press (Menu) > (Menu) (Returns you to Main Menu)
C. Capture Large Main Menu Icons:
1. Choose: Setup > Menus > Menu Style = Big Grid
2. Press (Quit) > (Quit) (should return you to the top of Main Menu -
most likely with 'Setup' highlighted in blue)
3. Press (+) until top of menu is reached (may already be there first
press)
4. Should now see two columns with a total of six application icons on
screen, with top left icon highlighted in blue.
5. Press and Release Power Button (Screen Capture is Saved)
6. Press D-PAD (Down) > (Down) so that the highlighted icon is now two
icons lower (same six icons still on the screen)
7. Press and Release Power Button (Screen Capture is Saved)
8. Press D-PAD (Down) > (Down) to move menu down two rows
9. Press and Release Power Button (Screen Capture is Saved)
10. Repeat steps 8 and 9 until you have reached the end of the Menu
(Menu may roll over to the beginning - if it does, press D-PAD (Up) to
return to bottom of menu)
11. Press D-PAD (Up) > (Up) to move highlight two icons up
12. Press and Release Power Button (Screen Capture is Saved)
13. Press (Menu) > (Menu) (Returns you to Main Menu)
D. Capture Small Main Menu Icons:
1. Choose: Setup > Menus > Menu Style = Small Grid
press)
4. Should now see three columns with a total of twelve (fully visible)
application icons on screen, with top left icon highlighted in blue.
6. Press D-PAD (Down) > (Down) > (Down) so that the highlighted icon is
now three icons lower (same twelve icons still on the screen)
8. Press D-PAD (Down) > (Down) > (Down) to move menu down three rows
E. Capture Small Main Menu Icons:
1. Choose: Setup > Menus > Menu Style = List
press)
4. Should now see a list of six (fully visible) application icons on
screen, with top icon highlited in blue.
6. Press D-PAD (Down) > (Down) > (Down) > (Down) > (Down) so that the
highlighted icon is now five icons lower (same six icons still on the
screen)
8. Press D-PAD (Down) > (Down) > (Down) > (Down) > (Down) to move menu
down five rows
F. Capture Setup Menu Icons:
1. Choose: Setup > Menus > Menu Style = Small Grid (just to make Main
Menu easier to navigate)
3. Choose: Setup > Menus > Setup
4. Press (+) until top of menu is reached (may already be there first
press)
5. Should now see a list of five (fully visible) setup icons on screen,
with top icon highlighted in blue.
6. Press and Release Power Button (Screen Capture is Saved)
7. Press D-PAD (Down) > (Down) > (Down) > (Down) so that the
highlighted icon is now four icons lower (same five icons still on the
screen)
8. Press and Release Power Button (Screen Capture is Saved)
9. Press D-PAD (Down) > (Down) > (Down) > (Down) to move menu down four
rows
10. Press and Release Power Button (Screen Capture is Saved)
11. Repeat steps 8 and 9 until you have reached the end of the Menu
12. Press D-PAD (Up) > (Up) to move highlight two icons up
13. Press and Release Power Button (Screen Capture is Saved)
14. Press (Menu) > (Menu) (Returns you to Main Menu)
G. Capture About Page:
1. Press (Menu ) > (Menu)
2. Choose: Setup > About
H. Email Screen Captures
1. Connect GPSMAP 66i to your Computer and Select "Yes" if prompted on
the GPSMAP 66
2. Open the GPSMAP 66i directory
3. Open the Garmin directory
4. Select the 'scrn' directory, right click > add to archive. (most PC
use similar context menu)
5. Step 4 should result in the creation of a new zipped or compressed
'scrn' directory
6. Email this 'scrn' zip archive to [email protected]
If, at any time, you have an troubles, please contact me for further
assistance!
Please remember to choose (Menu) > (Menu) > Profile Change > {desired
Profile} to return you to the profile you wish to use. Consider keeping
the GPSrChive profile on the device for the next time we may ask for a
screen capture.
Thank You!
