Is there a battery level feature on the 66i, other than the battery icon atop the display?
...or you can download one of the "battery widgets" from apps.garmin.com/.../apps. After installing you get a wonderful battery"meter" by quick-cliking the powerbutton and then press the right…
This is amazing. You actually have to download an app to see the battery level of a device used for emergencies ^^ It's cool that there is a workaround though. Thanks for the input!
I was not able to locate any battery widget compatible with the 66i on that site. Am I missing something. The only ones I can find are Data Fields which do not provide enough information other that battery…
Not during field use. At present, the only place you can see the actual battery level as a percentage is on the "charging screen". You can only see this when the device is actively charging AND you turn the device off.
...or you can download one of the "battery widgets" from apps.garmin.com/.../apps. After installing you get a wonderful battery"meter" by quick-cliking the powerbutton and then press the right arrow on the rocker. By the way - this is the way to open all sorts of widgets, for example a grid-reference widget, very handy….
Right On! Thank you. I will check out Apps!
...the one I use is called Battery Widget...
You can also place a battery level field on any screen which has customizable field content. However, this is just a larger version of the "analog" battery icon in the status bar. It still does not show the actual percentage.
Do note that the bar changes color at low levels. I don't know the level at which a color change occurs. You also get a pop-up text warning of low battery level.
As an aside, the use of CIQ widgets is a widely accepted approach to extending the functionality of Garmin devices.
I was not able to locate any battery widget compatible with the 66i on that site. Am I missing something. The only ones I can find are Data Fields which do not provide enough information other that battery %. Thanks
