Hi, Is there a trick here that I've not found???
I successfully download some imagery. Now every single download fails and goes back to Pending. restarting the 66i makes no difference?
Thanks!
Thanks!
Ok, further detail - when I reduce the detail to "High" from "Highest" it will download imagery. I did download the first lot of imagery on "Highest" - are there rules for places where you can and can't use the increased detail levels?
Hi.
I've noticed the same thing on my new 66i. Birdseye imagery works well on "normal" and "high" resolution but not on "highest".
The other thing I've noticed is that when downloading at "high" resolution Garmin forces a smaller download area. For the record, I've tried the above both on the unit directly and via Basecamp for Mac - same result.
For now just stick with "normal" or "high" it seems.
All the best.
Cheers, I did wonder if maybe Highest isn't available at our end of the world!
I think this has more to do with size of the download. OTOH, I do not know what resolutions are available for NZ.
Was this issue resolved in firmware 5.40?
