Hi, I just cannot make the download link for the manual work. Is there a trick to it?
Appears to be screwed up. I was unable to either download OR print the manual. The web version works, of course.
Appears to have been fixed. A separate PDF version is now available. Since the firmware is still changing frequently, you should probably use the web version when possible.
Thank you for the update, here's a link to the manuals:
https://support.garmin.com/en-NZ/?partNumber=010-02088-03&tab=manuals
