Z82 is not responding
My Z82 stopped responding today and the status LED has been stuck in solid blue. After holding the Power button for a few seconds, the blue LED was gone but came right back after couple seconds.
Any suggestions on how to fix this?
Jason
  • Can you get in the diagnostics menu settings and perform the test and mag. calibration?
    Press "up" key down and repeatedly press the "down/power" to get in this setting.
    cycle to the settings with the "measure red stripe" button.
    Have the z82 shut down again and try rebooting.
    If not working go back to the diagnostic menu and keep it in the screen test setting to let the battery drain.
    Then when battery is drained recharge and try to start again.
  • Refer also to support article link below for more info on the "Sleep Mode" feature on the Z82 as well is the soft reset is not prompting the display to power on through the viewfinder:
    My Approach Z80 or Z82 Won't turn on from Sleep Mode
