Z30 slope sometimes wonky?
On occasion, my z30 slope adjustment seems broken or im not understanding if it is adding wind/weather factors. I have it paired with s50 and premium maps subscription.
On many times, i would be staring at an obviously downhill flag and the range finder would have an up arrow and indicate it is playing a yard longer than the laser measure and vice versa. Not a gps or wrong hole issue. Is there something else it is factoring that isnt in the documentation? I know if its paired to s70 it could do wind. But I just have the s50.
  • I have the same problem.  So wonky at times and can't be trusted.  How can I turn the wind calculation off?  I don't need it adjusting that for me.  Just give me slope and i'll figure out the rest.
  • The Z30 does not factor wind into the distance lasered. Lasering the flag provides the arc to the watch and the watch provides the distance info to the point lasered (flag) to the front of the green, and from the flag to the back of the green.
    PlaysLike Distance on the watch may factor into the relay when paired depending on whether or not slope is a factor...but wind speed distance is not.
    Try lasering the green again to ensure the flag was locked on adequately in case the distance ranged was skewed due to objects in the background moving, like trees.
  • Helpful to know! Then there are definitely times the slope is just not correct. Cannot figure out why. Its not an accidental buzzing of a wrong target. I've had a few times where a flag that is obviously uphill or downhill have the z30 tell me otherwise. Any other thoughts like perhaps its not zeroing out what level is correctly?
  • Other than re-lasering the flag a couple of times...it should factor in the slope from there, Per my first reply, moving objects behind the flag may affect the acquisition of the flag like trees if the wind is blowing.
  • I have multiple times shoot the flag where it's 20 yds downhill, and it'll show me uphill on the slope. It's not always, but often enough that now I can't trust it.  I know how to shoot a flag and I'll borrow my buddy's bushnell and it'll be correct.  The actual distance is fine? But the slope calculation is frequently off. Maybe it's time for a warranty exchange
  • My Z30 is off by as much as 9 yards at times and shows me up slope when its down slope and vice versa..All my playing partners have Rangefinders with slope ,and when we zap the flag all of theirs are within a yard of each other while mine is way off..I bought this so I could sync it with my S70 watch..Might be time to go back to Bushnell..
  • I have owned the Z30 for about two years and have used it with my Fenix and Enduro watches. It pairs fine and I can shoot the flag.  But like others have said, there are most definitely times when it gets the slope wrong.  It thinks the flag is uphill when it's actually downhill, and vice versa.  It's only sometimes and I cannot reliably reproduce it. But it happens for sure. A fix would be most welcome.
