We are happy to announce the Approach Z30
For more info, access the main product page: Buy Here
Support Center Links:
Key New Features:
- Ranged distance syncs to compatible devices.
- See distance from the pin to the front and back of the green.
- PlaysLike Distance feature adjusts the yardage based on elevation changes.
- Range up to 400 yards with 6X magnification
- Built-in magnetic cart mount.
- Get up to 1 year of play with replaceable battery.
Range Relay:
- Sync the ranged distance to the pin with the Garmin Golf smartphone app or your compatible smartwatch or handled - plus see a laser range arc that reveals everything in play.
PlaysLike Distance:
- PlaysLike Distance lets you adjust the yardage for uphill or downhill shots based on the change in elevation from where you're standing.
6X Magnification:
- Quickly see the distance to the pin from up to 400 yards away with 6X magnification and vibrational feedback once you’ve locked onto the pin.
Magnetic Cart Mount:
- A built-in magnetic cart mount makes for quick and convenient ranging when riding in a golf cart.
Tournament Mode:
- An external indicator light lets you and your playing partners know when your device is in tournament mode.
Find My Garmin:
- When paired to the Garmin Golf smartphone app, you can use Find My Garmin to locate your range finder if it’s left behind.
