Approach Z10 Introduction
We are happy to announce the Approach Z10
For more info, access the main product page: Buy Here
Support Center Links:
Key Features:
  • Range Relay: Sync the ranged distance to the pin with your compatible smartwatch, handheld or the Garmin Golf smartphone app, plus see a laser range arc that reveals everything in play.
  • Playslike Distance: PlaysLike Distance lets you adjust yardage for uphill or downhill shots based on the change in elevation from where you’re standing.
  • Plan Your Approach: See distance from the pin to the front and back of the green directly through the viewfinder to quickly understand where the pin is located on the green. (When paired with your compatible Garmin device).
  • Magnetic Cart Mount: A built-in magnetic cart mount makes for quick and convenient ranging when riding in a golf cart.
  • Tournament Mode: An external indicator light lets you and your playing partners know when your device is in tournament mode.
  • Find My Garmin: When paired to the Garmin Golf smartphone app, you can use Find My Garmin to locate your range finder if it’s left behind.
