Approach S70 + CT10: Optional Manual Putting Mode Request
I am a very happy user of the Garmin Approach S70 together with CT10 club sensors. Overall, the system works extremely well, particularly for automatic tracking of tee shots, approach shots, club distances, and post-round statistics.
However, I believe the putting workflow could be significantly improved.
In my experience, CT10 detection works brilliantly for full swings, but putting is fundamentally different. Around greens there are many small putter movements which are not actual putts — for example repairing pitch marks, tapping the ground, leaning on the putter, or general movement around the hole. This often results in incorrect putt detection and requires post-hole editing.
I have therefore removed the CT10 sensor from my putter and now manually adjust putts after each hole. I suspect many golfers may be doing something similar.
My suggestion would be to add an optional “Manual Putting Mode”:
* Automatically track all non-putting shots as normal using CT10 sensors.
* Do not attempt to detect putts automatically.
* When the watch detects the player leaving the green, simply prompt:
“How many putts?”
* The user could then quickly select 1 / 2 / 3 / 4+ putts.
This would:
* Reduce false shot detection around greens.
* Improve scoring accuracy.
* Improve putting statistics reliability.
* Reduce post-round editing.
* Preserve the excellent automatic tracking for all other clubs.
Golfers are generally very good at remembering their total score and number of putts immediately after completing a hole, so this would feel like a very natural workflow.
A second, smaller suggestion:
The “Round Info” function is one of the most useful mid-round screens, but it is currently buried quite far down the in-round action menu. Allowing users to customise or reorder the golf action menu would improve usability considerably.
Overall though, the S70 + CT10 system is outstanding and remains the best golf watch ecosystem I have used.
Thanks, Paul
  • Hi Paul. Thanks so much for sharing your thoughts and ideas with us! We’re always open to new ideas and love hearing from our customers on what you want to see. If you have a particular idea you want to share, please fill out this form to get this sent over to our development teams:
  • Paul,
    Agreed 100%! I’m also seeing now since I’m manually setting the pin (or, by using my Garmin rangefinder that sets the pin) and marking each putt its not showing any stats at all under the putting measure? Do we have to utilize the CT sensors on the putter for us to see actual putter stats?? I to believe Garmin has the best system out there for not really promoting it as much as the others, but still for those of us that want analytics this is a must. - Bob Myers, Canton, Ohio
  • Hi  , you are saying 'or, by using my Garmin rangefinder that sets the pin'. I thought that the Approach Z30 can only see the distance, not the exact pin location? Is there maybe some new functionality that I may have missed that allows for the pin position to be registered (i.e. change the default middle of the green pin position). If so that would be awesome. Can you explain when/where/how to do it? Thanks!
  • Jimte, Yes; well, at least it does for my watch which is the Approach S70. It sets the pin location on my watch (showing the green). Now, it’s not always correct. Been a few instances where it was off quite a bit but I would say it’s been spot on 80% of the time. A friend of mine that had the Z30 showed me this feature and I rushed out and bought one for myself. Yeah, I’m a Garmin ***. LOL.
  • Thanks Bob (), that sounds very promising!
    Just to make sure I fully understand the workflow and functionality, and based on what I’ve read in several other forum posts, is the following correct?
    With the Z30
    Trigger: As I’m approaching the green, ideally before I actually step onto the green.
    1. I laser the flag with the Z30 (from anywhere on the hole, whether that’s 400 yards/meters away or 30 yards/meters away).
    2. The Z30 sends not only the distance but also an estimated pin location to the watch.
    3. I check whether the Laser Range Arc distance on the watch looks correct.
    4. I press START and open View Green.
    5. I verify whether the displayed flag position looks correct.
    6. If necessary, I manually adjust the pin position.
    7. I press BACK to return to the hole screen.
    8. I then walk onto the green and start my putting routine, based on suggestion of OP
    Goal: Use the Z30 as the primary source for flag distance and estimated pin location, and use View Green to verify and fine-tune the pin position if needed.
    Without the Z30
    Trigger: When I’m within roughly 30 meters/yards of the green
    1. I look at the watch.
    2. I press START.
    3. I open View Green.
    4. I manually set the pin position.
    5. I press BACK to return to the hole screen.
    6. I then walk onto the green and start my putting routine.
    Is this the best way-of-working and also provides the best data insights afterwards (e.g. on putting distance)?
    I’d love to hear how you use it in practice, especially if you’ve compared rounds with and without manually setting the pin position. Many thanks!
  • Jimte, Now, I’m not a Garmin rep, but your steps all look solid. I’m not sure which functions all the different watches allow you to do, I’m just speaking about the Approach S70 that allows me to see the set pin with the use of the Z30. Keep in mind, even by using these Z30 along with the watch and “marking each putt”, your info will not be reflected in the stats (Putts that is). Only way it records putt data is if you are using the CT sensors with the putter. Hope this all helps.
  • Great, thanks for the feedback Bob! I have a Garmin Tactix 7 AMOLED, which has (except for TruSwing and CT1 compatibility, not relevant for this use case) the same golf features as the S70 (https://garminrumors.com/your-guide-to-garmin-golf-features-every-watch-compared/). I am using the CT10 sensors on all my clubs, so I guess the stats should be OK too. I will check next time on the course. Thanks again!
  • I don't understand what is different in your suggestion compared to not using a sensor on the putter at all. I don't have any sensors and all of this takes place:
    “How many putts?”
    Pro for the sensor: it auto detects shots and you don't have to rely on pressing the action button on your watch.
    Con for the sensor: it auto detects many movements on its own that were not an actual putt (practice swings, etc) that have be manually erased afterwards.
    Without the sensor, you also miss out on putting data in the Garmin golf app, but there is essentially no value in that data.
  • Sensors allow putting stats, putts made within certain distances. Pretty much is what they do. This will show up under club stats
