Feature Request: Integration Between Approach S70 and Approach G82
Hello Garmin Team,
I’m a longtime Garmin user and currently use the Approach S70, CT10 sensors, and the Z30 laser, all of which work exceptionally well together. The ecosystem and data continuity are a big reason I’ve stayed with Garmin.
I wanted to share a feature request that I believe would significantly enhance the user experience: deeper integration between the Approach S70 and the Approach G82.
Specifically, it would be incredibly valuable to:
- Start and manage a round on either device (S70 or G82) with automatic syncing between them
- Share live hole data, scoring, and Smart Caddie recommendations across both devices
- Use the G82 as a larger, cart-mounted visual display while the S70 remains the primary wearable interface
- Seamlessly leverage CT10 and Z30 data across both devices without needing to choose a “primary” unit
From a user perspective, the S70 + G82 combination feels like it should be the ultimate setup—wearable intelligence plus a larger, glanceable screen—but today they operate more independently than expected.
I realize there may be technical or product-line considerations, but I wanted to share this feedback because it would meaningfully improve on-course usability without adding complexity.
Thank you for continuing to build such a strong golf ecosystem. I’d be happy to provide additional feedback or clarify use cases if helpful.
