All f a sudden at the turn (hole 10), the watch does not detect any of the CT1 tag after the shot.
Finished the round having to manually select the club.
Now trying to figure out what happened and how to fix it.
Anyone else with the same issue?
Ensure you are squarely and gently pressing the flat top of the sensor to the flat surface of the screen on your watch prior to each shot if you are using the CT-1 sensors...as they use RF which is very low energy and require that close proximity tap squarely against the face of the watch.
None of the sensor would work - regularly tried during the back nine with no luck.
Tried to change Setting/Golf Settings/Club Tracking/Approach CT1 enable off/on but did not fix the issue.
What I did finally was to restart the watch after the round was completed and issue was fixed.
I really beleive it was a software glitch.
Had a round yesterday, no more issue.
Same issue happened again during the last two rounds.
Watch would not detect the CT1 anymore in the middle of the 1st nine...
I have not yet update to 27.09
Happen again today after upgrading to 27.20
CT1 would not be recognized half way through the round
same thing happening to mine and its barely a week old. Stopped sensing any of the 16 tags mid round. Manually have to select the club. Haven't worked since. all settings are good. Watch restarted, software all up-to-date. and I am very religious atbout tapping it squarely on the watch face and holding it there for a few seconds. Frustrating as ***.
Same issue 2 days ago. By the 8th hole, the watch would not detect the CT1 anymore.
The watch suddenly start detecting the CT1 by the 13th.
My experience is that by the time I start a new round, the watch detect CT1 as usual.
I can only hope. But with my frustration, Im gonna have to return this item. Troubles are not worth it.
