Virtual Caddie is not working after updating for me
Update August 29, 2025:
Our engineers have indicated this concern should now be resolved. This was a fix on the backend with the Golf app. You will need to sync a new file for this. So upload a scorecard…
I've tried all the suggestions. Unfortunately, without success. It's a shame that Garmin isn't able to fix this as soon as possible.
Update as of March 10th, 2025:
Please open the Garmin Golf app on your smartphone. Then tap the Profile tab > Go to "My Bag" make an edit to your club type by changing the name of a club or something else…
Thanks so much for this, I actually did see that suggestion on another thread and tried it before a few previous rounds and nothing has worked to date.
is there an alternative process for IOS or is the operating system largely irrelevant?
is there any way to test if the Virtual Caddie is or isn’t working without being on an actual golf course or so it can be tested before trying to rely on it?
One more thing is that I’m using the Fenix 8, not the S70, not sure if that makes any difference? Thx
No, you can't test Virtual Caddie unless you are on the course.
The issue was in the backend of teh Golf App so it should work for any watch using the Golf App.
If you were able to confirm that the club name change you made was indeed well taken in account (synchonized) then inded the fix alone is not working.
When you open the Golf App on your phone, choose "Stat" then "Club Stats"
Do you see your bag with the target distance?
Make sure the watch club list is identical to the list in your Golf App - eventually change some name to reconfirm again that the watch and the Golf App are referring to the same "bag"
