I'm a bit confused about the Home Condition setting.
When I set this, is it always used as a "base" regardless of where I play? How does the watch determine when I'm playing at "home"? Do I need to manually update this setting whenever temperature and humidity change?
Where I live, humidity varies between 60-100% throughout the year, and temperatures (when I play) range from 0-30°C.
I was under the impression that the S70 would automatically pull this data from the weather information it receives via the iPhone app. Is that not the case?
