Considering the purchase of an S70, but have a question that I can't seem to find an answer to on the web or directly from Garmin.
I live at altitude (Denver) and I want the "Plays Like" feature to account for this. So, when I go to sea level (all else being the same), the Plays Like distances should be greater than the actual distances.
It appears that the watch has settings for Home / Local course conditions for the Plays Like feature. This is apparently a manual setting that could be for several purposes. It could be something that allows you to set "Local Conditions" when the watch cannot successfully communicate with the phone for example. Or, as I would like, it could be the altitude and weather adjustment factors from my "Home Course" used in the Plays Like calculations instead of assuming some baseline like 30 feet above sea level, 75 degrees, etc.
Can anybody confirm that this setting is in fact the Home Course conditions. It would be great if somebody has set this values at altitude and has actually seen the altitude adjustment in the Plays Like has added yardage say at sea level. Also, would be great if anybody could list the settings and / or provide a picture of them.
Finally, if the watch cannot connect to the phone, is wind speed and direction the only thing you lose when calculating "Play Like"? Are there other features that get compromised when you don't connect to the phone?
