Playing in 27 and 36 hole courses
I am using my Vivoactive 3 for golf right now. I play mostly in courses with 27 holes and there is no option to select wihch of the 3 x 9 holes you will play that day, so the scorecard is an  18 holes scorecard.
Instead, in just gives you the option to select between 3 different courses (9 holes each). So is like you played two different rounds that day.
I am very intersted in purchasing the approach S70 but the 2 x 9 holes situation is a deal breaker with me.
So, my question is, with the Approach S70, is there an option to select which two of the three possible 9 holes are you playing that day?
Thanks in advance
  • Answer is Yes: you have the option to choose between 9 holes or a combined 18 holes.
    You will select the first nine. Then the watch will ask you if you want to select the second nine (or not) and which one.
    Then the watch will ask you for the tee selection for both nine.
    Once you have selected both nine, you cannot update the selection.
    So if for any reason, you have to play on the back a different nine than the one you previously selected, you will need to end the game at the turn and restart a new game with the proper nine (resulting in 2 nine holes games)
  • Reached out to you via direct message to confirm the name of the course to offer some assistance. Please keep an eye out for my message in the message box located in the upper right section of the forums site.
    - Thank you
