Add green contour data s70 approach
Hi, currently testing the green contour subscription.  Looks like the two courses I use the most are not covered when I check the list.  Is there a way to get them added?   Also how can I request a refresh of course data as one of my courses has recently changed a couple of holes.
thanks..
  • Per the Which Golf Courses Support Garmin Green Contours? Garmin Support page, the Green Contours feature is not available on all golf courses due to certain factors resulting in the info being unavailable for some golf courses in the Garmin golf course database.
    There is a Garmin Golf course search tool linked here: Garmin Golf Courses on the website that allows courses to be searched by name, region, and country to determine if contours are available, and the tool also will show if the specific course was recently updated in our system.
    If a course is not showing Green Contours is available through the course search tool, there is a course report form that can be submitted through our site as well, link to report form here: Golf Course Report Form
    There is no guarantee that the report submission will result in green contours becoming available, as the availability is dependent on factors that are outside of Garmin's control in offering contours for every course.
    - Hope this helps!
  • Great thanks.   Have submitted my form, hopefully it will be sorted so I can try during my trial period.  Thanks for the response
  • Our golf map team will email you If any communications for contours on that course become available in relation to your inquiry.
    Please keep in mind that the green contours feature is not advertised as available on every Garmin Golf course map in the course database, and your inquiry will not necessarily be handled like a course correction for a map needing a fix for an issue-related reason.
