Hi
Where can I confirm the course rating and slope used by Garmin?
Thanks
Hi
Thanks
I saw it somewhere on my S60, but I did not use it, because I play on several golf courses and then I have to change it every time ...
I also do not use stableford, because I have on different courses different plying handicaps ...
Thanks
Unfortunately, none of the 3 possible choice (see below) provides information on slope/rating (which depend on the tee and course you are playing).
I suppose this rating/slope is wrong as the calculated Handicap from garmin is not correct.
Select Use Garmin Golf to use the handicap configured in the Garmin Golf app.
Select Local Handicap to enter the number of strokes to be subtracted from the player's total score.
Select Index/Slope to enter the player's Handicap Index® to calculate a course handicap for the player.
I sent the correct Slope/Rating for the course at www.garmin.com/.../
If you set up the round using the Garmin Golf App then you can see course rating and slope index. I find it easier to check my course handicap using the boards at the club and then enter as a Local Handicap on the watch.
