S70 issues etc
Hi
I have recently upgraded from the s60 - I couple of comments
Ending a round is much harder - here it is the last option in along golf menu. Golf menu should be editable - remove entries and change the order.  If not surprising that end round is last on the list.....
Ct10 pick up seems worse on the s70 - ie the times I need to manually enter the used club has increased......
The android Garmin golf app - you must add the ability to add or delete putts - without that the putting stats are useless. Picking up counts as zero putts - if it says 3 putts and you know it was only 2 I can't see how that can be corrected....
  • I completely agree. Editing a menu, removing items from the menu, re-ordering a menu seem like obvious wins for users. Adding a shot manually takes about 7 steps because it is at the bottom of the menu. And I find myself doing this once per hole.
  • Make sure that you have the correct "Wrist" set in the User Profile menu on the watch. To access, tap the middle button on the side of the watch from the time screen > Select Settings box > Scroll down and select "User Profile" > Then make sure the "Wrist" preference is set to left (if using right-handed clubs) or right (if using left-handed clubs) to ensure the watch knows the angle from which the backswing will be taken from.
    Ensure the watch is being used on the lead wrist as this will allow proper detection of the impact from the club facing hitting the ball during full swing shots.
    Also follow steps outlined on the My Garmin Golf Watch Is Not Detecting Shots Automatically Garmin Support article to ensure all other suggestions are being followed and shot detection should operate smoothly, especially if the Approach CT-10 sensors are in use.
    If you continue having concerns, please reach out to Garmin Support for further assistance to discuss the issue live with an expert so more probing questions can be asked in terms of the issue you are seeing compared to previous devices you have used in the past.
  • Watch picks up shots with no problem......
    Ct10s
    Other feedback
    Tempo training- and on course tempo should be recorded in the app (golf app would be best)  to get the most benefit out of this feature.  Having to look at your wrist after every shot is not ideal.
