Why is the watch updating every time I check for updates? I Can check for updates constantly and it keeps updating every time over and over.
Are you checking for updates directly on the Approach S70 using Wifi? ...or are you checking for updates via the Garmin Express program?
Based on the post, I am not sure if you are seeing an update version showing available to install repeatedly, or what specific is showing available to install on your watch.
Are you seeing an update appear available to install, after selecting the "Check for Updates" option from the Software Update section of System settings on the watch?
If you are seeing a version available to install, please confirm the version. Also please check the "About" section of your watch and confirm what version of software is currently showing installed
A solution we have found to resolve the concern, per the steps outlined below:
If you continue having a concern after following the steps above, please let me know. I hope this helps!
