S70 42mm - touch targeting not working.S70 42mm - touch targeting not working. The "Up" and "down" "buttons" on screen for bunkers/penalty areas not responding, nor any response with the slider to zoom in or out. Also no rea
S70 42mm - touch targeting not working. Product newly bought. The "Up" and "down" "buttons" on screen for bunkers/penalty areas not responding, nor any response with the slider to zoom in or out. Also no reaction to measure a distance by touching a point on the golf map. Software version 13.25. Please assist
  •  Make sure to tap the up and down arrow icons at the bottom of the screen with the point of your finger, a little higher up from the edge of the glass.
    If using a screen protector over the display, you may need to remove it as the touchscreen on the S70 is designed to be used without a screen cover installed over it.
    Also the most current version of software for the Approach S70 is version 14.36 so your software is also needing to be updated as well.
    If you continue to have concerns, please contact Garmin Support so they can discuss the concern with you live with an expert, so they can ask more clarifying questions, while having you actively troubleshoot the concern.
  • Thank you
    After updating the software it seems to be working fine.  Will check it out on course tomorrow Slight smile
  • Thank you for verifying!
