S70 swing tempo doesn't work.
I just got S70 for replace my s62, So try to use Swing Tempo mode in driving range but when I swing it just freeze in same .
no data I try many time and change to other speed but it not work.
please advice .
  • Reaching out to you via direct message to get some additional info on the concern you are having with using the Swing Tempo features on the S70.
  • Same, just got the s70 and swing tempo training doesn’t register the swing at all
  • Open settings on the watch from the quick access menu > Select "User Profile > Make sure the "Wrist" setting is set correctly for the wrist you wear the watch on.
    Ensure the watch is also being worn on the lead wrist when golfing (if right-handed, wear on left wrist) (if left-handed, wear on right wrist).
    If you have further concerns, it may help to discuss your setup and further specifics to gauge what could be causing the concern when you are using the Tempo Training activity app.
  • Do you actually have to hit a ball. I wanted to just swing the club to get the tempo
  • A ball is required. For right handed golfers, the user must also ensure that the buttons are not getting pressed from wrist movement, hinging, or from the glove as well.
    Ensure you are wearing the watch above the glove, securely on the wrist, with a compatible quickfit 22 band fitted adequately during temp training sessions as well.
