Power Charge is not working
A few factors to consider if you are encountering difficulties in getting your Garmin watch to charge:
Water should be used first, or 70% isopropyl rubbing alcohol may also be used if something further than water is needed.
Below is a link to the Garmin Support page showing more info on cleaning the charging…
Some things you can try - Troubleshooting for Charging
The troubleshooting article also mentioned in the other comment from seilogramp is also a Garmin Support page resource that should also be reviewed if having issues as well.
clean in between the studs on the watch
Is there a recommended way to clean this connection? Using a solution/cleaner?
Below is a link to the Garmin Support page showing more info on cleaning the charging contacts for reference if needed:
