S62 Not charging beyond 85%
Hi,
My Garmin S62 won;t charge beyond 85%? It will charge normally until it reaches this level then it stops? Is this a battery save feature that needs to be disabled?
Thanks
  • If using a 3rd party watch face, tap the middle button on the side of the S62 and reference the charge % from the top of the main menu to see what that value is showing.
    After confirming watch % is not increasing from the system menu, if the % is not increasing...perform soft reset on the watch by holding the middle button until you see the display on the watch force itself off  (takes about 10-15 seconds) then release > Power the watch by on briefly holding the same middle button til the triangle logo appears and let the watch reboot back to the time screen > Then confirm what the % is showing from the menu once again.
    Connect the watch to an alternative power source as well like a USB port through a home computer > When connected to a computer you should see the watch display a locked charging screen since the watch is in USB mode being read by the computer.
