My S62 just recording my shots on several hole, not every hole in a round. The shots tracking record also incorrect. I have tried reloading the App which has not helped. The issuse has only recently appeared.
Hello, can you try syncing that shot data manually with Garmin Express?
How to Sync Data from a Fitness Device to Garmin Connect | Garmin Customer Support
This should push that shot tracking data over…
Do you recall seeing the AutoShot indicator on the watch after each shot you took? It sounds like previous scorecards has that shot data.
Anything change in regards to the type of balls being hit, or how…
This should push that shot tracking data over to the app. This should only be a one time workaround.
I have tried this but it dosent work.
Anything change in regards to the type of balls being hit, or how the watch is being worn (should be on lead wrist)?
I can see the Autoshot indicator on the watch and it shows the distance normaly. There is no change in regards on shot or the watch being worm.
