On the golf performance stats on connect I see comparison for drive, approach, recovery but not for putting. I only get the average for other players. I enter my putts for each hole
Do you have the Garmin sensor attached to your putter? I believe that is needed to get detailed putting info.
no I don't but I am entering putts for each hole manually
Without the CT10 sensors, there's no ability to record putt distance, hence the count of # of putts on each hole is all you will get
I enter putts and it records them as a number but doesn't show me versus "similar handicap" does on the other segments chip, drive etc etc anyone any ideas ?
I have the exactly the same problem. Did you get a solution?
The Approach CT10 club tracking sensors are required, with a CT10 paired and attached to your putter in order to get putting performance stats to track with the Approach S62.
The Approach S62 can only track full swing shots, so putts and chip shots are not natively tracked with the watch alone.
I'm having the same problem. Also no stats are shown, even though I add my putts manually. With entering the # of putts we should still be able to compare with others, or see whether putting is improving/declining right? Or is this truned off by design?
Unless the actual putt length is being measured, putting stats are meaningless, hence why the use of the CT10 is required to make that measurement.
Drive, Approach and Chip performance can partly be calculated because the watch itself is measuring a distance for whatever club you are using by indicating manually or getting club info from the CT10.
I don't agree with this. Average putts per hole is not a meaningless statistic, in fact it is a useful statistic that can be used for
1. Comparing how my putting is to other players similar to my level
2. To see if my putting is declining/improving.
Average putts per hole can easily be calculated from the entered number of putts per hole, so I don't understand why it is not shown in the garmin golf app.
