What is the correct way to register a lost ball or out of bounds?
Say I hit my driver as my tee shot, and it might be lost, so I hit a provisional. Even though I select Driver for both shots, in the Garmin golf app when later reviewing the round, only one drive shot is registered for this particular hole.
If I manually add another tee shot (by manually setting it's locations to the tee) and tagging the end result as either Lost ball or out of bounds, the distance of that shot is set to like 1m, since it then uses the next(actual) tee shot as the second shot, if though I set it as oob/lost.
In the statistics it will then show a 1 meter driver.
I can't figure out what the designed way to handle these situations are?
