It shows 0 calories burned after running for 2 miles on an elliptical and then 1 mile on treadmill
Can you check your Activity Class Settings in the Garmin Connect app and make sure it isn't set to 0?
Thank you for the reply. I went in to check this and it says Activity Class is set to None. What should it be set to?
You can view a breakdown of the activity class and what would be the best number for you to set it at.
I just set this to 6 based on working out 3-4 days a week for a little over 1 hour per workout.
That will likely resolve the issue, if set to 0, calories may not be calculated.
I just did tried the Elliptical activity and did the elliptical motions but it still is showing 0 calories. Any other ideas?
Also want to note that I tried saving a hike (walk) this weekend but it took forever to save the activity. It is still taking for ever to save or discard the activity.
Please force close the app and restart it. You could also restart your watch. Please check your user profile to make sure everything is correct (age, weight, gender, activity class). If those are all accurate, please hover over my name and send me a private message so we can gather additional details and investigate this issue further.
Please also make sure the watch is up to date with Garmin Express. You can also try to reset the watch.
Press Menu > Select Settings > System > Reset > Reset Default Settings
Looks like this fixed it, thanks!
