Select 2 x 9 Hole Courses on a 27 Hole Golf Course
It appears that there is no way to select 2 x 9 holes on a 27 hole golf course on the G80, is this correct?  Seems like a pretty big deficiency as I do not want to end and start a new round (screws up the Stableford scoring system.  For such an expensive piece of equipment can this be fixed?  With other non-Garmin GPS units, you could simply ask them to combine the nines if they did not exist, does Garmin offer to do that?  If not, will look to return it.
Top Replies
All Replies
    I am apologize, there is not. It will depend on the course you play with the Approach S62. When you can combine two 9 hole courses on 27 and 36 hole courses, you will be prompted when you first started the round, which two 9 holes you will be golfing and saving into one scorecard.
