Ability to add more than 14 CT10 sensors
I have a few extra clubs that I will rotate in and out of the bag and purchased an additional 3 pack of sensors.    I would prefer to keep separate stats on these clubs to see how my performance is using these clubs.    There appears to be a limitation to only 14 active sensor connections being paired on the watch.   Is there a work around to connecting the other sensors?
  • The maximum amount of CT10 sensors you can have is 25. That number would be less if there are other sensors paired to the watch, such as a bike cadence sensor for example.
  • Thanks for confirming that.   should adding these be possible through the watch?  I am not getting prompted to add new .. (currently I have 14 paired)
  • Yes, it should be possible through the watch. The only time this may be an issue is if you have more clubs than sensors, you would have to go in and forget the sensor to pair it to a new a club. So if you have 17 clubs and 17 sensors, you should have no issues. But even then, you should still have the option to 'add new' under the sensors and accessories settings on the watch.
    Please make sure your Approach S62 is up to date with Garmin Express. You can also try to reset the watch. You would have to re-pair all the sensors again.
    Press Menu Settings System Reset Reset Default Settings
