I am considering buying the Approach S62 as i am a keen golfer but also want to improve my running. I have read that you cannot get the coach or training plans of the S62 but can you upload run profiles (e.g. intervals) at all?
No. If you want to have the level of Run abilities that you are describing, you will need to consider buying a Fenix series watch that has all the worldwide golf courses on it just like the Approach S62. If you go with the middle 47mm size Fenix, it will be the same size as the Approach S62.
Please note: you can still buy a Fenix without the golf mapping on it and you will still be able to load several Golf courses on the watch through the Garmin Connect Mobile APP to play courses around the world. You would have to remove and add them when you play different courses.
