Greetings to everyone in the community, it's Mattia here.
I recently bought an Approach S62 to keep track of my data and hcp variations on the golf courses and the watch's HW is totally perfect I should admit.
Btw, I think there is a kind of mis-match bug on some golf courses. In Italy I noticed it. (maybe this bug is present and similar in other countries)
When you get the GPS signal and select a certain course to play on (Tolcinasco in the specific case), the smartwatch correctly shows you the field on which you are playing during all the 9-holes match.
The garmin is obviously paired with the smartphone's bluetooth and its gps.
Once I finish the match, if I would like to check my results back home or from garmin golf app, it shows me another one of the three possible 9-holes paths present on the golf course, but not the one I played onto.
I can barely see some shots if the chosen golf path is near to the one on which I played, but I cannot change the path anyway.
The only workaround way is to create manually another golf record on the right 9-holes path and add manually the shots remembering the irons/woods I used...
Does someone has noticed a similar issue?
Best regards,
Mattia
