Approach S62
Unit ID 3332261911
SW version 2.50
Issue:. Gesture to activate backlight does not work.
Approach S62
Unit ID 3332261911
SW version 2.50
If your gesture feature is turned on, and you are putting your arm in front of you and then rotating your wrist towards you to activate the feature, but you still cannot get the gesture feature to work…
Thank you for your reply. I checked backlight settings. They were correct. So I reset the watch (in the settings). It now works. I had turned it off and on, but did not think to reset.
If your gesture feature is turned on, and you are putting your arm in front of you and then rotating your wrist towards you to activate the feature, but you still cannot get the gesture feature to work correctly, please reach out to Golf Product Support. We will be happy to assist you further.
