While total round score shows correct number of shots of my game, hole by hole score wrongly corresponds to the shots of player 2 instead. It happens both in Garmin Golf app and web.
It looks like the records are messed up someway.
Based on your description, it would be an issue with your Approach S62 and the scorecard it is creating. I apologize for not fully understanding your issue in the private message you sent me. If the odd…
Sorry Chris I wrongly posted the issue in the S20 section while it relates to the S62 instead. I had entered the 2-player scoring before and no issues, so probably it is an isolated case. I will try it…
Based on your description, it would be an issue with your Approach S62 and the scorecard it is creating. I apologize for not fully understanding your issue in the private message you sent me. If the odd behavior of your S62 remains a 1 off situation, your Approach S62 may be fine.
However, if the issue continues, there is valid concern for issues developing with your watch that need to be addressed by resetting your Approach S62.
- You can hold down the middle left power button until it shuts off then let go for a soft reset or use the Restoring Defaults in the support center article.
Sorry Chris I wrongly posted the issue in the S20 section while it relates to the S62 instead. I had entered the 2-player scoring before and no issues, so probably it is an isolated case. I will try it further and let you know if the problem persists.
Thanks!
