The Hole View is not showing the Map View of the hole.
It only shows the distance to the front, middle, and back.
If you changed your Golf Settings to Big Numbers mode, the fairway and green does not have room to display off to the right side like normal. Your Hazards and Layups option will pull up the image and your Move Flag option will show you only the green.
