Hi my S62 would not connect through Garmin Express so performed a system reset leaving my data intact.
The watch is now frozen with a large triangle on the screen and none of the buttons respond.
How can I correct this problem.
Thanks Pat.
Thanks Pat.
Panic over, after 2hrs of being frozen it has burst back into life !!!!
my has been frozen for over 2 weeks, none of the buttons respond, except the menu that turns it off and beck on, but to the same frozen triangle screen, I can't do anything with it, it is just completely unresponsive!
Mine has not, it's been 100% unresponsive and frozen with the greenish triangle in the middle, just like yours was, what did you do to it to make it respond/work again?
Thank you
Steps to resolve your concern with the Triangle not loading past are outlined on the Garmin Support page linked here: My Approach Watch is Stuck on the Garmin Logo
The first recommended step is to hold the middle button on the side of the watch until the logo disappears and the screen goes blank. Then power the watch back on and the triangle logo will appear again. See if the watch then reboots past the logo shortly after that.
If the watch is still not loading past the triangle, then follow the reset steps for the S62 outlined in the article I linked above.
