Using Ct10 sensors, some short chip shots or bunker shots around the green are not detected.
I've noticed around the green, that even with the CT10 sensors, some chip shots and bunker shots around the green are not getting detected.  I don't think that it is a sensor issue because the same clubs are detected fine for longer shots.
  • They definitely have issues catching some of the finer shots. This is an issue for all club sensor vendors as far as I know. We can add shots after a round in the app on your phone when that happens. This is one of this issues "it is what it is".
    0 Former Member in reply to vonbonds
    I disagree that it is a problem with the sensors.  The club is detected when it's removed from the bag but if it is not a full swing then it is ignored.  The putter uses the same sensor and has no problem with short swings.  My suggestion to fix it would be increase the sensitivity when in close proximity to the green.  I've used Arcos as well and that has no issue with detecting chip shots.
