Each hole map and club distance
My Garmin recorded my map of the golf course and the distances as we drove around. It recorded my scores as I was playing and my distances of each shot. When I downloaded it to the Connect app, all it showed was the map of where we drove, there was no score or yardages for the map on each hole.
  • The scorecard is viewed through the Garmin Golf app separately for the activity that was recorded and showing in the Garmin Connect mobile app.
    My recommendation is to install the Garmin Golf app to your smartphone, sign-in to the account, then view your scorecard through the Scorecards tab in the app if you recorded a scorecard during your golf round while using the Approach S60
  • I understand that but the last two rounds it does not show on the golf app
  • If the steps on the Garmin Support article: My Scorecards Are Not Displayed in the Garmin Golf App have been followed, I recommend connecting your watch to a home computer via USB connection using the charging cable > Then open File Explorer (if using Windows) or Finder (if using Mac) to open the device drive for the S60.
    Once you have opened the device drive for the Approach S60, you will see a GARMIN folder > Open GARMIN > Then open the SCORE/SCORECARD sub-folder to see if any .FIT files are listed within that have a creation date matching the rounds missing > If you do not see any scorecards, then somehow the scorecard was not saved for the rounds that are missing.
    • If you are seeing .FIT files showing creation dates matching the missing rounds, I recommend opening the Garmin Express program on the computer and syncing your watch to see if they then transfer.
    • If you are seeing a bunch of .FIT files listed in the SCORE/SCORECARD folder, and syncing through Express did not result in the scorecards transferring to your account...then I recommend clearing all of the files within the SCORE/SCORECARD folder to free up some space, then record rounds going forward and the scorecards should not have any issues saving/syncing over to your account.
    Please contact Garmin Support if you need assistance with the steps above...or if you continue to have concerns with scorecards recording after following the steps outlined above.
