My S60 is continually freezing on the course and this is making it unusable. It is updated to SW8.90. It is plugged in to Garmin Express to ensure everything is up to date.
This has been an ongoing problem.
If you recently installed map updates to your S60, see if the concern continues on your next round with the watch. If the maps have not been updated in a while, and the device has not been synced for a while, a combination of outdated satellite prediction data (which is updated in the background when the watch is synced) and a build up of files from activity tracking...scorecards, etc can lead to the concern you mentioned.
After syncing your watch and installing any updates showing available, if you continue to have the concern I recommend following the reset steps outlined on the Garmin Support page linked here: https://support.garmin.com/?faq=YDnGs9PF698oh44odgPbO9&productID=554662&searchQuery=freezing&tab=topic
I recommend contacting Garmin Support if the concern persists after following the suggestions outlined above.
