S60 not working unless plugged in
If I plug it in it shows it charging and it is currently at 92%...then if I unplug it it is black screen dead...??
  • Hold the middle button on the side of the watch until the display goes completely blank (takes about 10-15 seconds of holding) then release the button.
    Then connect the watch to USB port on a home computer. You should see the watch go into USB mode locking the charging screen. See how the watch charges from a computer USB source going forward.
    *If the watch is still having the issue of powering off and not back on after disconnecting from the charging source...I recommend contacting Garmin Support to speak with a Golf Specialist discuss further available solutions.
