Alternate Tee boxes and Approach S60
At our club we sometimes play the course backwards, or will hit to #6 green off #1 tee and so forth.  I can not get accurate yardages to the green unless I am standing on the appropriate tee box.  If I am on the correct tee box, yardages will vary as I move farther or nearer to the green, but if I get off the tee box, the yardages to the green are generic for the selected set of tees and do not change until a shot has been struck.  Any way around this?
  • There is not. Your distances all come from the image of each course hole and walking between your ball locations and the green. You can manually change between each hole for a shotgun start but not based on the type of scenario you are describing while having fun and doing something unique.
